Hello guys, Terminator arrived few days ago..
The BlackShadow Terminator is an LED flashlight with four CREE XM-L U2 LEDs for up to 3500 lumens on max output. The light is controlled by a switch conveniently located on the attached handle and is powered by four 18650 batteries (not included).
- Dimensions: 132mm (Length), 69mm (diameter of head), 93mm (Height)
- Weight: 395g (Without Battery)
- Three outputs (XM-L U2): 3500 lumens (1h10m) - 1500 lumens (2h40m) - 400 lumens (11h25m)
- Accessories: Tactical parachute-cord, Spare O-ring, User manual and Warranty card.
- Stainless steel bezels
- Impact-resistant optical tempered glass lens with anti-reflective coating
- Heat sink fins
- Aluminum alloy body with abrasion-resistant surface finish anti slip rhombic knurling
- Design offers a decent overall grip
- Aluminum alloy tail cap with rhombic knurling, can tail stand
- Four premium CREE XM-L U2 LEDs, rated Max 3500-lumen output
- Custom designed metal reflector offers perfect beam profile.
- High-performance push button switch. Slightly click the switch to turn on the flashlight and change the brightness mode among High-Mid-Low-OFF. Pressing and hold the switch for more than 1 second to turn on or off Strobe mode.
- Power indicating system: The indicator light is green when the power is available, it will change into red and flash three times every second when the power is low.
- The indicator light will flash when the flashlight in on standby state, which will help you to find it easily in deep dark or complex environment.
- You can completely shut off the power to save the energy, by loosening the head a half turn if in long periods of inactivity.
- Built in digital control system, powered by 4 pcs 18650 batteries (not included)
First impressions
Pro
- Very nice build quality, similar than other top chinese brands
- Perfect anodizing, no scratch etc. (HA Type-II)
- Smooth thread
- Clean reflectors, lens with perfectly centered leds
- Beautiful neutral white tint
- Excellent beam quality, very good balance (throw-flood)
- Hidden strobe mode
- Temperature control
- can run 1, 2 or 3 pcs 18650 battery (not only 4pcs)
- Relatively small size with awesome output
Con
- no memory
- visible pwm flickering low and medium mode (high mode is perfect, no pwm!), but when I use outdoor, the pwm is not too annoying, especially medium mode.
other
- simple UI, 3 modes, but not too user friendly, always low-medium-high-off
candle lamp, Terminator review
http://www.candlepowerforums.com/vb...adow-Terminator-(4xXM-L-T6-NW-4x18650)-Review
Beamshots (I will add more pictures later) Click images for higher res
Blackshadow vs Xeno F42 V2 R5nw
Blackshadow vs Sunwayman T20CS
Blackshadow vs Spark SL6S-740NW
Blackshadow vs Nitecore MT26
Blackshadow vs Fenix TK35 U2
Blackshadow vs Olight SR51
Blackshadow vs Armytek Barracuda
Modes
more pictures coming soon
- Heat sink fins
First impressions
Pro
- Smooth thread
Con
- no memory
other
Modes
