Wasn't getting any replies over on the other thread, so am trying a new one. Just got an RRT0 XML and had a few concerns for current owners.
-If tail switch is On, keeping the ring in Off position for a few sec. puts light to sleep. Turning it back on with the ring then takes a second or two for light to wake up. Normal? No mention in manual.
-It says XML 550Lm on the box, but any other way to confirm that it is? I know there were older LED's in this model also.
-LED isn't centered at all, though I don't really see any effects. The outer fringe of the beam is some odd slightly different color though. Don't remember what.
-The control ring is smooth for the most part, but occasionally, if you press down on it (as though using a flashlight side button), it will bind up a bit. Is this normal?
-The ring also has noticeable play (not excessive) in the "up-down" direction--towards and away from the surface of the flashlight body, if you will.
-Lastly, the SOS mode is annoying so far. It keeps coming on when I don't want it. I know it's because I'm just playing with the brightness levels, but who knows if it will stay annoying. They need a better method for this mode that I think no one has actually used, EVER.
