**Pictures** Nitecore P25 Smilodon (1*18650, XM-L U2, 860lm, 20000cd)
gopajti
Hungary
:popcorn:
Official website
http://www.nitecore.com/productDetail.aspx?id=74
from P25 User Manual
Features
- Premium CREE XM-L U2 LED
- Maximum output of 860 lumens
- Integrated "Precision Digital Optics Technology" provides extreme reflector performance
- Boasts a peak beam intensity of 20,000cd and a throw distance of up to 283 meters
- High efficiency circuit board provides up to 325 hours runtime
- Integrated dual Picatinny connectors / rails provide a huge variety of mounting options
- Innovative single button two-stage switch offers a user-friendly interface (patented)
- Intelligent charging circuit with voltage detection charges safely and rapidly
- Integrated micro USB charging port is water, dust and impact resistant
- Eight rapidly switchable brightness modes to select from
- Integrated power indicator light displays remaining battery power (patented)
- Power indicator's secondary function displays battery voltage (accurate to 0.1V)
- Intelligent memory function stores preferred brightness setting
- Integrated with impact resistance & reverse polarity protection (patented)
- Stainless steel titanium-plated two-way clip
- Stainless steel retaining ring protects the core components from damage
- Toughened ultra-clear mineral glass with anti-reflective coating
- Constructed from aero grade aluminum alloy
- Sturdy HAIII military grade hard-anodized
- Waterproof in accordance with IPX-8 (two meters submersible)
- Impact resistant to 1.5 meters
- Tail stand capability
Length: 160mm
Head diameter: 40 mm
Tube diameter: 25.4mm
Weight: 171g (without battery)
Accessories
Quality holster, clip, tactical ring, lanyard, USB cable, spare tail cap, spare O-ring
Warning: 18650 rechargeable Li-ion battery only. Do not attempt to charge non-rechargeable batteries or RCR123 batteries.
NOTE
The above data has been measured in accordance with the international flashlight testing standards ANSI/NEMA FL1 using one x 3.7V 2600mAh Nitecore 18650 battery and 2 x 3V 1550mAh Nitecore CR123 batteries under laboratory conditions. The data may vary slightly during real-world use due to battery type, individual usage habits and environmental factors.
Battery installation
Insert one 18650 battery or two CR123 batteries with the positive pole pointing forward (toward the light head).
Momentary illumination
Momentary illumination can be achieved by switching off the flashlight and then half pressing and holding the tail switch. Release to turn the light off.
SWITCHING ON/OFF
To switch ON: Press the button on the tailcap until a "click" is heard.
To switch OFF: Press the button on the tailcap a second time until a "click" is heard.
General Operations
Tips:
1. The P25 utilizes a 2-stage switch similar to a camera shutter button. The light's numerous functions are selected according to the depth the switch is pressed.
2. With the light turned on, press the switch partway down in quick succession will cycle through the brightness levels: ultra-low, low, medium, high, and ultra high.
Operating in Turbo Mode
With the light turned on, press the switch partway down and hold to activate turbo mode.
Note: For user safety and to prevent overheating / failure, the P25 will automatically switch to high mode after twenty minutes of use in Turbo mode. Press the switch partway and hold to reactivate turbo mode when needed.
Standby Mode
With the light turned on, press the switch all the way down and release within one second to enter into standby mode. In this mode, the light will consume small amounts of power to maintain the settings in the MCU (micro control unit) but appear to be turned off. When in standby mode the power indicator light will flash once every two seconds to show the location of the light. To exit standby mode, simply press the two-stage switch all the way down or press the tail switch to turn off the light.
Tips:
When the standby mode is on, you can access all the modes and brightness levels by simply press the side-switch.
Special Strobe / SOS mode and Location Beacon
With the light turned on, press the switch all the down and hold to enter strobe mode. When in strobe mode, press the switch partway down to cycle through SOS, location beacon and strobe modes. To select any of these modes simply release the switch when it is displayed. To turn off the light fully press and release the switch.
CHARGING FUNCTION
The P25 is capable of charging a protected 18650 li-ion battery via the included USB cable. Simple install a protected 18650 li-ion cell, plugging one end of the USB cable into the flashlight and the other end into a universal USB port / adaptor as shown in the adjacent image, and the P25 will take care of the rest. The P25 needs to be turned on in order enter charging mode.
CHARGING INDICATOR LIGHT
1. Fully charging a depleted 18650 batteries takes approximately 6 hours.
2. Under normal charging conditions, the blue indicator light will blink once every 0.5 second.
3. If a problem is detected during the charging process, the P25 will stop charging and the blue indicator will blink rapidly. This is usually caused by faulty / incorrectly inserted battery, or without turning on the light by pressing the tail switch.
4. When charging is complete, the P25 will stop charging intelligently, and the blue indicator will illuminate steadily.
Caution:
1. The P25 needs to be turned on in order enter charging mode.
2. 18650 rechargeable Li-ion only, do not attempt to charge non-rechargeable batteries or RCR123 batteries.
POWER TIPS
1. When the light is on, the power indicator will blink once every two seconds when power levels reach 50%.
2. When the light is on, the power indicator will blink consistently when power levels are low.
3. Each time batteries are inserted or the light is put into lockout mode, the power indicator light will blink in various patterns to indicate the battery voltage (accurate to ±0.1V). For example, when the battery voltage is at a maximum charge of 4.2V, the power indicator will blink 4 times in quick succession, followed by a one second pause and two more blinks, indicating a total battery voltage of 4.2V.
CHANGING / CHARGING BATTERIES
When the power indicator blinks rapidly it means the batteries need to be replaced or recharged. Alternatively if the light becomes dim or unresponsive to adjustment this also indicates batteries need to be replaced or recharged.
MAINTENANCE
Every 6 months, threads should be wiped with a clean cloth followed by a thin coating of silicon-based lubricant.
my impressions
Pros
+ Excellent build quality, perfect anodizing
+ Clean, dust free reflector, lens
+ Perfectly centered led
+ Smooth threads, o-rings are excellent condition
+ Very good beam quality (no rings)
+ No visible flickering (pwm etc), all modes are perfect
+ Silent driver (in all modes)
+ Good throw capability, 20000cd (better than most XM-L flashlights in this category)
+ Extra modes are hidden (sos, strobe, location beacon)
+ Direct access to the brightest mode
+ Real low mode, 2lm (EC25 (60lm), MH25 (40lm), MT26 (25lm)
+ The low mode is not greenish, yellowish, all modes are cool white!
+ Voltage checking, standby mode flashing
+ I really like the UI
+ Rechargeable
+ Working with longer batteries, eg. XTAR 18700 (no rattle)
Cons
- Not working with unprotected/flat top batteries
Other
I tested the rechargeable function with XTAR 2600mAh and 3100mAh batteries and precisely stopped 4.20V always (after few minutes I measured 4.19V).
click images for higher res
Nitecore P25 vs Nitecore MT26
Nitecore P25 vs Sunwayman T20CS
Nitecore P25 vs Spark SL6S-740NW
Nitecore P25 vs Xeno F42 V2 R5nw
Nitecore P25 vs Lumintop Hunter T5, XP-G2 R5
roadkill1109
T5's still the bad-*** thrower! Your beamshot picture and video made me pull the trigger on this light! :)
kj2
The Netherlands
Something in me says; Get this light! :D -but the "must-use" of button-tops cells withhold me a bit :thinking:
gsgtsg
How does the Nitecore P25 compare to the EC25?
What are your opinions?
Cheers.
gopajti
Hungary
Nitecore P25 vs Olight SR51 (weather: rainy, foggy)
holylight
Germany
very good review. clap clap :D . Wish more review like these !! shouldnt review be move to review section?
holylight
Germany
P25 very hungry for battery thats the negative about it, when turboing. any solution ? :D
( fully charged non japan cells will auto shut off the light running in turbo in less than 10 sec and some cannot even on it) lol
holylight
Germany
Flattop cell don't work, I got these enerpower+ black 3400mah button head and now I got this beast working.
