Ghostwalker54
Recently purchased a Tranquility Base head that either wasn't actually taken apart to see if it was original or the individual knew and represented it as such anyway. Whoever modded the head did a halfass job of it. The emitter is the same as Don's McGizmo Haiku, Sundrop or Mule in that it looks quite similar and has the same threading (Don's drop-in will fit perfectly). Unfortunately this has a cut down aluminum reflector that has been cut down a little too much on the top and bottom and had been poorly shimmed with a small teflon washer that still allowed the LED to screw in too far so that contact with the battery was intermittent. I have corrected the problem with a larger thicker teflon shim and shoved a small band of aluminum around the reflector with an O-ring on top of that to seat it against the glass evenly but have a sizable gap at bottom of at least 2 to 3 mm between emitter and reflector. I have seen, up close and personal, at least 2 other of Scott's E size Aelph heads that were almost identical and everything appeared to size up perfectly.
Question 1.) Is there anyone that can provide a custom reflector if I give them the dimensions?
Question 2.) If I can't get an XM-L drop-in from Don for whatever reason is there anyone else here that makes this type of screw in emitter?
Question 3.) Does anyone here make a slightly crenalated Ti bezel ring to fit this?
Any knowledge base, advise, etc given will be greatly appreciated. A few photos to shed some "light" on the questions.
[/IMG]
[/IMG]
[/IMG]
