Re: Types of LED\'S????!!!!
UV-
SMD stands for Surface Mount Device, which means it does have not any wires to solder. It is meant to be soldered (mounted) to the contact pads directly onto the surface of a circuit board.
There are SMD resistors, capacitors, diodes, ICs etc. Nearly any part with wire leads can be obtained in a SMD package.
There is nothing magical or brighter or better about SMD LEDs it just means they don't have wire leads. They do tend to be smaller though.
GregR
