I'm a fork lift truck engineer and I prefer neutral, as uncool as it sounds when working in dark engine bays covered in grease and oil I think an incandescent light is best, especially when slightly under driven (if that's the right word).
Hi jamie.91.
You can have the grease and oil!!! :nana:
I have seen and been amongst quite enough of that stuff in my working life thank you very much!
Is it because you are used to incandescent work lights that are mains or 12V DC powered that you prefer the neutral and warmer colours when working on your stuff?
Maybe you just like the the warmer tinted LED lights better than the neutral tinted ones as you said you like them when they are under-driven and therefore warmer usually.
At least LED flashlights or work lights do not break as easy as the older incandescent globes that used fragile filaments that were mains or 12V DC driven as I know all too well in my trade.
I also did a lot of work inside cars when I was installing car alarms and car radio gear.
I would think that you would be using sturdy multi-LED work lights by now with LEDs replacing every type of light around nowadays.
The big choice of LED based lights that are available now must really make your job a little bit easier when working in dark engine bays etc.
It may just cut down the amount of swearing (cussing) that us trade guys do when we get frustrated because we can't see the area we are working on properly.
The job is hard enough to do at times without having low light issues thrown into the mix.
Things like LED equipped flexible optical fibre lights and cameras are really great and I only wish we could have had them when I was doing maintenance on all kinds of gear.
Plumbers have really good gear available now to help them see blockages and also in working out which direction a pipe runs in under the ground.
I don't think plumbers would be too worried about what colour tint their LED lights were to see with when looking through pipes.
I think they would more be interested in being able to see what they have to see clearly, get the job done and have a break away from what they have seen enough of for the day (the mind boggles).
I did work on sewerage systems including tanks, pumps, level controls in pits and sewerage ejectors etc but I did not like the smell like most people wouldn't.
I don't know how plumbers get used to that stench especially when first starting out in that business.
I am glad that I became an Electrician (sparky) although plumbers charge higher rates than Electricians from my experience.
I think virtually everyone benefits from LED technology and they don't have to be a tradesman to know what the word LED is all about as that word is used so commonly nowadays.
With the vast array of LED house lighting fittings that are available today there is still a choice that has to be made when selecting the colour of the light source to be used in their light fitting that suits their taste keeping in mind the area that each light is to be installed in.
A simple choice between Cool White and Warm White has to be made at the very least when buying any new light fitting including LED based ones.
Daylight or White coloured fluorescent tubes were most often used in office lighting from my experience although some people in their particular area preferred Warm White to carry out their job.
WARM, NEUTRAL, WHITE or DAYLIGHT is all a matter of personal taste and the situation of where the light is to be used in any choice of flashlights or any other type of lights IMHO.
I realise that there is a lot of funny lines that could be used relating to plumbing above but I am not going there!
I just know that someone will be itching to post them to me. :laughing:
"Keep it clean" is all that I can say!
Yeah I know, another pun. :naughty:
CHEERS
