hello folk's -
HCRI eyes help needed!.
they say (according to google stuff), 4300 k is best for the majority of our eyes, then If so, would this matter if a flashlight made with say a 4500 - 5000 HCRI be just as good as it has HCRI to compensate?...if that's correct, or are are these two different matters?.
I also see cars with the 4300 set up, which is best for road use, I assume, but then why do some flashlight manufacturers make higher brighter lights, like BMW at 5000k, & forgetting our eyes need to see better?. is that where HCRI comes in to alleviate this ?.
so now even BMW have 5000k lighting now on new models...No HCRI ?. so how is that good for our eyes?.
they say 4300 gives out more light too, but my 5000 LED pd32ue seems brighter.
i know all our eyes are different, but the majority...
thanks.
:thinking::thinking:
Yeah, the Tint (ºK) has nothing to do with accurate color rendition, and, cooler tints are brighter for a given LED.
A tint is MOSTLY about personal preference for how you want things to look. If you want things to look yellower, you want a warmer tint. If you want to SEE IF something is there, for the same LED choice - you generally go with a cooler tint to get more lux on target...as the cooler the tint, the more lumens a given LED can typically produce.
If you need to know the color accurately, tint is not the answer per se...as some tints are better for some colors, but worse for others....you trade one part of the spectrum for another.
CRI, is supposed to describe the color rendition...and it does mostly, but, not perfectly. It does give a RELATIVE idea though, if comparing the CRI of different lights, the higher CRI will
tend to be more accurate at least.
After that its about priorities. SOME work I do requires either good rendition, or, exaggerated rendition of frequencies of interest. I do forensic investigations for example, and use UV light (An extreme frequency choice for the example) because certain things about my target are DE-emphicized, and certain things are exaggerated....so that the part I am LOOKING FOR is going to stand out.
Its the same for disaster response/search work. The likelihood of finding someone mostly revolves around separating them from their background. Its a combination of color and lux on target. If I have night adapted vision, I can't see color really anyway, so LUX is king. If my eyes are not night adapted, and I am relying only upon the light's beam I am carrying to see what's out there, I can still distinguish colors. For some searches, night vision is a double edged sword.
If my eyes are adapted, I need less lux on target to resolve the target from its background....but I can't use color vision to see potentially useful color patterns.
If my eyes are not adapted, I need more lux on target, but, I still can also use colors to delineate patterns of interest, etc.
MOST of the time, I'll see more overall w/o color but more light on target....in an adapted state...as more lux generally helps to resolve targets better than more color does.
So, if driving down the road one night, and you don't want to hit a deer or go through a pot hole....color is rarely the top priority, lux is. As lux is the light bouncing back you your eyes, and our eyes perceive a certain frequency best...we have a better chance of seeing the deer/pot hole sooner with that frequency to work with...AND with the most target light bouncing back to our eyes.
So, as more lumens being sent out tends to produce more lux on target for a given LED/Lens combo...they pick an emitter set-up that tries to get more light to do that. This can mean the light is cooler than the optimum eye receptor range, so maximize the total lux, but not too far above that range, to maximize the optimum receptor range. (Obviously, we see in ALL the visible spectrum range too, so we see MORE if we can ALSO use other parts of the spectrum than just one band, etc)
