Bicycleflyer
Hi all,
I have a Surefire Stratum and I want to know the working voltage. Specifically, I would like to know the lower limit more than the upper. But if you happen to know that too...great. My reason for asking is I recently decided to bore the body out to accept an 18650 cell (my first mod). The flashlight was originally designed to use CR123 X 2 which is 6 volts and the 18650 is only 3.7... so can I expect shorter run times with the 18650? Performance wise the 18650 seems to do as good as the CR123s. I don't have any special equipment to measure this, but I took the flashlight outside and ran it with both types of batteries and the brightness seemed the same. The 18650s I am using are Ultrafire 3000 mAh protected cells. I know asking about expected run times when using a rechargeable battery seems silly, but I am just curious.
Any answers, thoughts, and suggestions are appreciated.
