EDC Plus / IS X60L3 Triple LED P60 Dropin ( High CRI / Neutral White )
neutralwhite
London Heathrow
do any modders have this drop in already ?.
also does one LED just give like 150 lumens if it was just on its own ?.
then there is a better reason to maybe have 3 right?.
thanks kindly...
EDCPlus/IS X60L3 Triple LED P60 Dropin (High CRI/Neutral White)
$74.99
EDCPlus and Illumination Supply have teamed up to bring you the X60L3, a triple LED dropin that is low on cost, but doesn't skip on an ounce of quality! The dropin was designed with the user in mind, and comes in a diffusor/head tool case, and even an AR lens to maximize the output from the dropin. Unlike competing dropins, the X60L3 has been tested in an integrating sphere and is compliant to the ANSI FL-1 test. The LEDs - 3 Nichia NVSL219AT-H1 , are being driven at 2A, and puts out an extremely efficient 465 High CRI lumens rare in such a small package. This is achieved by our custom LED board and full copper unibody construction. For eelctrical conductivity and appearance, we have also silver plated the copper.
Introductory Pricing! Use the coupon code: X60L315 to get 15% off from now till the end of January! (While supplies last)
Specs:
  • Powered by 3x Nichia NVSL219AT-H1 High CRI (92) 4500K (Neutral White)
  • Modes: 3 Mode (High, Medium, Low)
  • Current: 2A +/- 100mA
  • Input Voltage: 3-6v
  • Supported Cells: 1x18650/17670 Li-ion cells or 2x CR123 Primary Lithium cells. Do NOT use 2x RCR123/16340 Cells.
  • Dimensions--Length: 29mm (40mm with spring), Weight: 38g (1.3 oz)
  • Compatible with: SureFire P, C, Z,
Features:
  • Pure Copper with real silver electroplating for superior thermal and electrical conductivity
  • Triple XP-G2 Optic with up to 90% optical efficiency.
  • Reverse polarity input protection
  • Over-discharge protection ~2.75v (applies only to High and Medium modes)
  • Gold-plated spring
  • Linear current regulated. No PWM.
  • Thermally potted driver
Includes:
  • X60L3 Drop-in module
  • 60DC (case, removal tool and wand)
  • 28.5 x 2.9mm AR glass lens
This Dropin is OUT OF STOCK, eta 6 weeks.
https://illuminationsupply.com/edcp...d-p60-dropin-high-crineutral-white-p-320.html
neutralwhite
London Heathrow
hi blimey, ok, thanks, lol.
thought I was way behind..
btw,..if there was just one of those LED's in a flashlight would they already give over 400Lumens, or does it all matter on the driver?.
i thought because its 3, the LED output must be like 150L each.
thanks.
It was only announced today, with a 6 week lead time. No one has one yet.
mvyrmnd
Australia
Yes, the outputs would be 150 each. A single 219 would have to be driven extremely hard to get to 450 lumens.
By having 3 emitters at a lower current you get efficiency gains - you'd need to drive a single LED with more than 3 times the current to get to the same output.
neutralwhite
London Heathrow
thanks for that.
appreciated.
S1LVA
Rhode Island
Looks like you copied the text from the webpage before it was finished being created. Craig just announced over on the MP that the drop-ins are in stock.
S1LVA
KarstGhost
I've got one of these on the way! Will report back with impressions whenever I get it :)
twl
TN
Anybody know if these EDC+ drop-ins will fit in a Malkoff or Elzetta host?
kyhunter1
South East KY
How is the fit of these in Surefire 6P hosts? Not really heard anybody mention it yet. I like the way Malkoff designed his with a small bezel gap to elimenate any electrical contact issues. I would hope this new module has the same fit.
neutralwhite
London Heathrow
would a solarforce host come with a window?, seeing as the drop in is not the actual window.
does the drop in come with a window AR Lens?.
Includes:
thanks.
moshow9
El Paso
Includes:
thanks.
Take another look at what you just posted being included. ;)
mvyrmnd
Australia
All of this is irrelevant. The solarforce host has a glass window. If the dropin comes with an AR window, then SCORE - you get a nice little upgrade.
neutralwhite
London Heathrow
thanks, and what happens then now to the solarforce window?.
ok to have two?.
easy to remove the Sforce window or leave it?.
cland72
There is a gap like the malkoffs have
Sent from my PC36100 using Tapatalk 2
neutralwhite
London Heathrow
what would you maybe suggest ?.
thanks.
no mention of solarforce re compatibility....
Specs:
  • Powered by 3x Nichia 219's R5's
I think the lens that comes with it is to big for the solarforce.
