hello
1)one cree flashlight has one mode,no regulation,no pwm,and consume from the batteries 300mA.
2)second cree flashlight has 3 mode,no regulation,but uses PWM to to get 300mA on low mode.when in the high mode the flashlight consume 1400mA.
the two flashlights are using 3*aaa alkaline batteries.(like duracell or energizer).
so if i use the second flashlight(the one that uses pwm) with only the lower mode,does it affects different on the batteries compared with the first flashlight?(discharge time?too much load on the batteries?)or the affect on the batteries will be,exactly,the same on both cases?
because at the second flashlight,even that the average current is 300mA(by using pwm to reach this average current from 1400mA by lower the duty cycle rate)the battery,practically,experience,high pulses of 1400mA.(despite of the fact that those high current are not constant,and come as pulses).
so,doesn't the batteries suffer from this high current pulses compare to the batteries that give real constant 300mA on the first flashlight?or it is,exactly the same?
thank in advanced.
thank in advanced.
