WilsonCQB1911
Which should I get to play with all the various P60 LED drop-ins available?
C2 is my personal favorite. It feels sturdier and easier to grip. I added an Oveready Triad tail cap just to make it that much better.
I would go for a simple solarforce l2, l2p or l2t for 18650 batteries. The reason is. When im done pimping my hosts, (mc-clicky switch, ar coated lense, drop in module, boring for 18650, etc). It's not mutch surefire left exept a expensive alu tube with a better name stamped on it. Solarforce is cheaper and accept 18650 batts out of the box.
A "pimped" and bored out surefire are not more rugged than a "pimped" solarforce.
I guess the next question is do I really need another flashlight? ....
.... I'm way beyond my ability to justify this many lights.
Youre right, havent tought about that for years I foil wrap the drop in, or use brass shims for a super tight fit and better heattransfer. For my malkoff modules i prefer the malkoff host for the hi/lo ring.But may be good to know: Malkoff dropins don't work in Solarforce hosts without modification.
I guess the next question is do I really need another flashlight? Will a C2 with the latest and greatest drop-in really add that much to my already bloated collection? I'm way beyond my ability to justify this many lights.
You already have a C3, so you already have a P60 host. It's up to you whether or not you can/want to justify another light.
If you can justify it, I would say get a 6P or 9P to complement it, and call it good. However, if you really enjoy the pocket clip and grip ring your C3 has, you may want to go with a C2.
Yeah but it seems that many of the drop ins specify only 2 batteries. So I'm not sure of I can use the c3.
What about a Z2? It is a mix of the two.
If that's the only issue, you can put a dummy cell in the tube to take up the space of the 3rd battery, and problem solved!
If you have a drop-in that can take 9v, such as a Malkoff, then you can use a pair of Lithium-Ion 17500, which are the same length together, as 3 CR123, and will fit right into that C3.
