bumpy. read from HKJ that there are more better ones than AW out there these days that could do the job better.
AW isn't everything really.
Well, you should only compare protected cells that are based on the same base cell. Don't compare an AW 2600 with any other that holds 3400 mAh
Protected cells with the Panasonic NCR18650B inside should have almost the same values (capacity, voltage curve under load and so on). For me the reasons to use an AW 3400 instead of any other protected NCR18650B based are:
- small size (important, because the NCR18650B has an higher diameter).
- manufacturing quality
- reliability
There is a thin metal stripe that connects the cells "+" to the PCB - look at
http://lygte-info.dk/info/BatteryRewrapping UK.html. Failures of the insulation will cause a short circuit. That's why I'm using either protected cells from manufacturers that I trust - or even unprotected cells, if the flashlight is suited for them.
Ah, and the AW 3400 isn't yet on HKJs web site.
