If you are a McGizmo purist, hit the back button. You will not want to see this Ti-PD modification. Otherwise, check out the mod that I did for a CPF member who asked for his Ti-PDS to be turned into a "WOW" light.
This Ti-PD now sports a Lux-RC 334 10 watt triple XP-G light engine rated at 1075 lumens. To push the lumens forward, it is using a narrow Carlco triple optic drilled for tritium vials. The tritium vials are green 1.55x5mm vials fresh from Bart. The first two levels are very similar to a modified TI-PDS, with an output of approximately 8 and 260 OTF lumens. The low and medium will provide you with illumination very similar to a standard Ti-PD. High is for a wow factor at more than 800+ OTF lumens. The piston and twisty still work, but to advance a level you must back off instead of tightening. The high level can only be used for short bursts, as the thermal protection kicks in. The heat can't dissipate into the head quick enough. (If this were an aluminum PDIII, it would likely last considerably longer on the high level.)
The heatsink is turned aluminum, shaped like an inverted top hat. It is press fit into the head for optimum contact, and uses thermal paste for extra heat dissipation. Because the light engine contains the converter and LEDs, I made a custom PCB, and turned a brass contact ring on my lathe. The piston contacts the ring in the same manner as with a stock PD, minus the kilroy for low. The levels are activated with a touch of the piston, or twisting the head.
Profile shot of the light.
Straight on view of the optic.
From the top.
Contact area with turned brass ring and custom PCB. I had some fun with this.
Drilled optic with bright green tritium vials. (Night setting on point and shoot Samsung camera, long exposure.)
Low beam. Medium and high were not playing well with my camera. (Beam is not textured, ceiling is stipple textured.)
We don't have any white walls in our home, so a white wall shot is impossible.
From the top.
