I stumbled across a nice long tutorial on using LTSpice:
http://www.ieca-inc.com/images/Spice-Simulation_Using_LTspice_Part_1.pdf
On the section for DC-DC switching converters, they do include this caution:
These circuits use complex simulations and realistic inductance properties because an oversimplified inductor
model will cause errors or simulation aborts in many applications. Very expensive simulation software versions
use special (and secret) tools to avoid these problems, but we have only the normal Berkeley SPICE kernel......
With the following rules you can avoid most of these problems:
a) Never use an ideal inductance -- always add a series resistor (even 0.01 can do the job!).
b) Every inductor has a winding capacitance, and often the circuit has additional stray capacitance. This
always gives resonance effects with (sometimes) unexpected results and problems during the
simulation. So use damping resistors or long simulation times to get correct simulation results.
