Contact MagLite CS. Tell them that your light does not turn on (or off, if that's the case). They will ask you if the batteries are good and if the bulb is good. They'll also ask you if the batteries leaked in the light. If you answer yes to the first two questions and no to the third then, more than likely, they'll ask for your shipping address and send you a replacement switch.
