I'm looking for a bit of help with my 2D to 4AA Mag project. The machining and custom work aren't the problem, the electronics are. The Mag I have is an older, we'll call it a 1st gen, LED model. I'm going to cut it down and size it for 4AAs. I'm looking for a good balance of output and run time, with a simple on/off set-up. I can either run the light at 3v with a series/parallel battery configuration, or at 6v with a series config. Any suggestions, advice, input, etc would be great. The light is pretty much going to be used as a general camping/outdoor light.
BTW, I tried the search, but didn't turn up much as far as the electronics.
Thanks!
-Brian
Thanks!
-Brian
