ShineOnYouCrazyDiamond
I am not sure if I should post this question here or in the Custom Flashlight page.
But either way, my question pertains to the NBBx2 driver and the 27LT with a LuxV
The third light in the McLuxIII-Series, this time with the McR-27L and a DBx2 driver. Think of it as a hybrid between the PD and the HD45 on a 2x123 chassis. Comes with a LuxIII UX1K and offers extreme toughness and technical finesse. Alternate versions include the LuxV variant with the NBBx2 driver as seen on the HD45 above ... and ... the McLuxIII-27LT-S with the Seoul P4 LED instead of the LuxIII.
I recently acquired a 27LT that I thought was a S version with a Seoul LED but received it to discover that it was the LuxV version. The S version is easy to mod to a newer LED with the DBx2 driver, but the LuxV has a more solid heatsink so it will prove a bit more difficult.
The real question has to do with the driver. As a test I hooked it up to a XML and a XPG to see what the current measurements would be before finalizing the setup. They were through the roof as though the LEDs were getting a direct drive with only the Kiroy connected. With a single LiIon the XML measured at ~1.6A. With 2xCR123 it measured at ~2.1 A.
I imagine that has to do with the much lower Vf of the Cree leds. Does anyone have any other thoughts on this that would help with this LED upgrade?
