BirdofPrey
- Joined
- Jan 12, 2007
- Messages
- 449
Ok, got my Smilodon from Fasttech yesterday. While I'm impressed with the brightness, I have a fairly considerable problem.
I put a fresh Eagletac 2400 battery in and after a couple minutes of playing around with it, I noticed that the blue indicator light was rapidly flashing. I hadn't read the manual yet so I looked and found that this indicates a nearly dead battery. I knew this couldn't be right but I changed out for a freshly charged Eagletac 3100. Low and behold, same thing. More reading taught me how to use the voltage meter. Using this indicated 4.1 volts.
Confused, I continued tinkering. Found that highest settings would fail to come on intermittently.
I tried using the built in charger and the light would indicate that the battery was full and would not charge more.
I also notice when the light does come on high, the beam will faintly and erratically flicker. Not overly noticeable but it is there.
So now I'm at a loss. Suggestions? Attempt a replacement? Being that it came directly from Hong Kong, I think this may be a bit of an ordeal.
Just looking for ideas. If I can fix or get this fixed, I can see this as being an excellent work light (which is what I bought this light for).
Sent from my ridiculously large Galaxy Note 2.
