If you need 100 lumens to light up an area with 10 lux at 15 m distance, then you need 1600 lumens to get 10 lux at 60 m distance with the same beam profile and 6400 lumens at 120 m distance. So I don't see an end to how many lumens one need.
When you start putting on binoculars to see what your flashlight is pointing at, you might have gone past the useful limits.
At this point, I want better phosphors, and for more companies to have thorough design and testing.
* Near-immediate output loss, with no warnings, no moon mode, no step-downs, etc., is a design failure, for a mass-market flashlight, plain and simple (IE, custom and small-run pocket rockets are not what I'm talking about). If it does not give 20% or more of its battery life on max (if multimode) in dimming output once the battery can't hack the output anymore, somebody dropped the ball (clear step-down to lower modes, and/or a battery level warning, would also be OK ways to handle it).
* Pocket-sized torches still commonly lack thermal throttling, both for your protection, and the LED's. If the whole unit weighs well under a pound, but can pull 3-5W, it should either have thermal throttling; be a custom/small-run unit; or have been extensively tested to be able to handle it without a human holding it, to make sure it will survive OK,
and not become burning hot after constantly running on high, with no skin contact, for hours on end. IIRC, the Arc brown board incident was long before I even got here.
* Few torches have a good flood beam, for us non-tactical, and non-tacticool, users (ironically, proper tactical hosts are the easiest route towards getting that taken care of, right now).
* The lumen race still seems to be most important thing to manufacturers, despite technology now out there to actually let you see what you are looking at better than a few more lumens would (neutral with higher CRI than cool, and high-CRI emitters).
* Ergonomics are too often still that of a simple stippled cylinder. Proper changes in shape are categorically superior to knurling, except on very small pocket flashlights, where size matters more. Surefire and Streamlight, among others, haven't trended away from knurling/checkering as the primary grip mechanism for no reason (it's not bad to have, but too many lights are simple cylinders with knurling--my guess is to save on machining costs).
I want a
better flashlight, far more than a
brighter flashlight. On the whole, flashlights flooding the market today have a great deal of room for improvement, even without getting much brighter all the time.
