I found this
http://www.sunwayman.com/html/products/201303/116.html
Features
● CREE XM-L U3 LED, with a lifetime of up to 50,000 hours;
●Tail cap tactical forward clicky switch, slightly depress the side switch for different output modes:
one turbo mode, three constant output modes, hidden strobe, slow strobe, police strobe and SOS functions(below is the output and runtime of using one single 18650).
Turbo mode : 600 lumens
Three constant output modes: 350 lumens (2.4hrs) – 75 lumens (12hrs) – 8 lumens (104hrs)
● Constant current circuit, constant output;
● Effective range of 300 meters;
● Uses one single 18650 or two CR123A/RCR123A/16340 batteries;
● Built-in charging module, can be applied to one 18650 battery, NOT 16340 or RCR123A batteries;
● Working voltage: 3~8.4V;
● High quality metal reflector maintains great throw distance and spread with an ideal beam pattern;
● Dimensions: 153.8mm (length) x 41.3mm (head diameter) x 30mm (tail diameter);
● Weight: 163g(battery excluded);
● Aerospace-grade aluminum alloy, solid and stable construction;
● Military specification Type III- hard anodized body;
● Waterproof, in accordance with IPX-8 standard;
● Ultra-clear tempered glass lens resists scratches and impacts;
● Tactical tail cap press button switch for momentary on;
● Accessories: charger, holster, O-ring, rubber cap, plug, lanyard.
Features
