ErickThakrar
(This product provided by the manufacturer for review.)
Today I have the pleasure of introducing a product from a brand-new manufacturer in the flashlight market; Yi-Light, and one of their first entries, the AK21.
A little about Yi-Light first.
Yi-Light is part of a larger manufacturing group that produces a variety of product categories. Originally started in 2006, the Yi-Light flashlight division is relatively new but leverages the manufacturing and engineering experience of the other divisions in the company.
So, let's get to the meat of the matter, the AK21.
We will start with the specifications as per the usual. Bear in mind that these are copied directly from the Yi-Light website and as such the English could use a little polishing.
LED: The United States imports of CREE XM-L U2
Reflector: Precision metal smooth reflector
Drive circuit: Digitally constant current circuit
Lens: Toughened ultra-clear glass lens with anti-reflective coating
Material: Aluminum alloy
Battery: 1* 18650/2*CR123A/2*16340
Modes: Low: 5LM /145Hrs
Mid: 135LM/12Hrs
Hight: 630LM/1.8Hrs
Strobe: 630LM
Color: Military gray
Finish: Premium Type III hard-anodized anti-abrasive finish
Size: head diameter 38.3mm x body diameter24.5mm x 153mm length
Net weight: 150 grams (without battery)
Waterproof: IPX-8
It is worth noting the range of outputs that the AK21 comes with. 5 to 630 lumens is a wide range.
The video will cover most of the features of the light and I'll cover the rest with the following pictures.
Overall impression of the AK21 is quite favorable. Solid construction, decent to excellent machining quality and a great feature set, makes the AK21 an excellent first entry for Yi-Light. Their specifications appear to be spot on as the performance I saw during the testing period closely mimicked the numbers listed by Yi-Light.
There are a few details I would like to see updated as far as the design goes, notably relating to the pocket clip. I mention this in the video, but the clip is just a little too long, which means that it impinges on the lip where the barrel meets the head of the light. Making the clip just a little shorter, but otherwise keeping the shape of the clip, would go a long way towards making the AK21 easier to clip to webbing, a pocket, or what have you.
I would also recommend that the bend near the top of the clip, where it joins the ring that secures it to the barrel of the flashlight, be dropped down below the top line of the barrel ring. That would make securing the clip with the aid of the grip ring significantly smoother and the damage that occurs now would be avoided.
In essence, the only concerns I have about the AK21 are largely cosmetic and easily remedied by Yi-Lights' engineering team. Now, add in an MSRP of less than 90 dollars and we have a pretty serious contender here. Outstanding budget light option, especially considering the features and performance. Currently, Yi-Light is looking to secure dealers in the US and elsewhere. At this time, all purchase inquiries should be directed to Yi-Light.
Definitely recommended. Outstanding value for the price.
Mid: 135LM/12Hrs
Hight: 630LM/1.8Hrs
Strobe: 630LM
Waterproof: IPX-8
The AK21 is by no means a small light, but is still a very manageable size. A great light to toss in a pack or similar. |
The magnetic control ring has a very smooth action, with positive detents. Very easy to use and it allows you to "pre-set" the light to a desired output before turning it on. |
The grip provides anti-roll capability and a much improved grip on the light itself. It also has a standard tripod mount option. Very handy for area lighting uses. |
The reflector is deep and smooth, capped with an anti-reflective coated glass lens. All of which is protected by a stainless steel crenelated bezel. |
The bezel easily unscrews, without risk of losing the lens, and provides for ready attachment of a variety of filters. |
The threads on the tailcap are square-cut and very smooth. O-ring seats are cleanly machined and should easily provide water-resistance to at least the IPX-8 standard listed. |
The threads on the head end of the battery barrel are also square-cut, although not anodized. That is largely to be expected on most lights these days. |
Beam shot of the Ak21. Note the relatively concentrated beam. Very "throwy" for an XM-L light. Of note, the camera pitches the hue of the light far more into the bluish than it is with the naked eye. |
This is the part of the grip ring that contacts the top part of the clip. As you can see, the part of the bend that rubs against here causes some damage to the grip ring. |
