Malkoff XM-L2 Hound Dog Neutral is a 5000k T6 limited edition with just a little over 1000 lumens at turn-on, but it will drop under 1k lumens after it reaches thermal stasis after warming up. No thermal step-down, and it holds a quite good percentage of its output when warm. Gene does a very good job with thermal management.
It's a great light with a McGizmo reflector and Malkoff build quality, and you can select the length of the battery tube you want to have on it, for the run times you want.
1.8" head diameter, so it has some good throw and some nice wide spill, and is not too big.
Worth looking at, in that category.
