Hello All,
I have replaced my stock G2 LED emitter head with a (320 lumen XPG-R5 5 mode 26.5mm x 29.3mm 18v max head). With the main spring removed, the bezel screws down almost all the way tight, but it will not light. If I slowly unscrew the bezel maybe a 1/16th of a turn it will light. The flashlight only functions within a half bezel turn range, otherwise it is off. Is this purely because of fit? I think even with a spacer it would not function properly.
Thanks,
3Ghost
Thanks,
3Ghost
