How to open a JETBEAM RRT 2 Raptor
OverLight
Hello everybody,
Can you tell me how to open the JETBEAM RRT2 Raptor ? I can just open into 3 parts, the body, the head and the tail
And I can not open more the head
Thank you for your advise
blackFFM
You have to unscrew the stainless steel bezel ring from the head.
Flucero28
If the RRT-2 is anything like my old style (XRE) RRT-0, after de-soldering the leads from the LED and removing the PCB there will be two screws underneath that need to be removed. The head can then be disassembled. Be careful not to lose the spring and ball bearing that reside in the adjustment ring upon disassembly. Also take note on how the driver is clocked inside the head for proper re-assembly. Hope this helps.
Frank
