kansaswater
- Joined
- Mar 12, 2013
- Messages
- 1
Hi Folks,
I've read this forum for years (and very impressed), first time posting (hopefully in the correct area), looking for some EE guidance. I'm searching for a component, and any input would be highly appreciated. In effect, I'm looking for the equivalent of a multi-channel MOSFET.
With your standard LOGIC N-channel transistor, say FQP50N06L, simply pop the gate with 20mA, and 700mA will flow between the source and sink to light up LEDs. The logic level 'type' is handy for high efficiency and utilizing various PWM, which I've tested successfully at some respectable frequencies.
Like most of the kind, this fet is disconnected (off) till hit with a control signal, then switches active (on) when triggered, allowing the current to pass. For my design, I need the equivalent. However, I'd like channel A "on" all the time. When the control signal arrives, it switches channel A "off," and routes the power through channel B (turns channel B "on").
In hopes of making myself understandable, think of a railroad switcher. The trains can cruise down the main avenue unimpeded, but bump the switching post, and the trains travel down another rail.
It would make sense for this magical component to exist, I just don't know what it is, and have come up empty in my searches. Roughly, it needs to be as cheap, same size, quick, and readily available in a similar capacity to what I mentioned above. Heck, add another pin to the FQP50N06L with this functionality, and life is groovy.
Any advice? Thanks for reading.
