Flip-up diffuser for EagleTac T20C2 MkII?
awyeah
Loving my EagleTac T20C2 MkII. It came with a screw-on diffuser (replaces the crenellated bezel). I'm wondering if there's a flip-up diffuser that I can use instead?
__philippe
BE
EagleTac T20C2 bezel outer diameter is 1.38 in (35.0mm)
I do not know of any flip-up diffuser to fit this specific diameter.
However, if you can tolerate instead a "slip-over-bezel" rubberized difffuser, (no bezel unscrewing necessary),
the Olight M20 Diffuser (diameter 35.5mm) should fit, somewhat loosely:
http://www.candlepowerforums.com/vb/showthread.php?359692-Olight-Filters-Diffusers-for-all-seasons&highlight=diffusers
For a much tighter fit, you might perhaps also consider the Nitecore NFD34 (diameter 34mm)
Cheers,
__philippe
