Impressive, maybe, but fraught with problems, and actually dangerous in many cases. The reviews listed on its own site feature many of these problems.
From Popular Mechanics article "And as we recovered our vision, our sense of smell alerted us to another concern: melting metal from some smoldering contact coils within the flashlight. After less than two minutes, the battery was blackened and giving off smoke..."
From TechCrunch "Making things even worse, you read that the Torch should only be used for about three minutes at a time, lest the thing become too hot to hold. Indeed, the Torch gets hot during use." And this isn't a gentle stepdown, this means turn it off or you might start a bigger fire than you intended.
From Gizmodo "But the heat this thing gives off is not all fun and games for pyromaniacs. It also severely limits the usability of the flashlight. After a few minutes of use, the Torch becomes too hot to hold in your hand...And, to be quite honest, the scary charging unit above is fairly unreliable. I found myself frequently resetting the magnets because it registered a full charge prematurely. Obviously, I can't recommend something this expensive, impractical and, quite frankly, dangerous..."
If these are the reviews that Wicked Lasers is highlighting, I wonder how bad some of the others were. You could buy a very nice 18650 light and a blowtorch for considerably less than the Torch, and you'd have better performance in both areas. Hate to be a downer, but until they make it reliable and at least marginally safe, I would stay away.
