nuambenzina
I am curious is someone is using here GREEN light on the headlamp, and what advantages is having the GREEN light over the RED one.
My Best Regards and Thanks in Advance!
I was courious as I saw some headlamp with "green for pipe inspection", and I also saw green in some hunting clips with green light.
Also I have a Gu-10 led spot which is with some 5 mm led's and is changing color like in a disco.
In the night time when in the room is very dark and is green, I can see things quite well compared to red, when I can see things but not as clear as in green and that maked me wonder how will be in a cave / caving / speology to use green light or green + white in the same time.
If there will be some details seen better like cracks/slots/slits in the caving walls with green instead of the "normal white" that a led head lamp is giving, as red dosen't give such a good "contrast".
