E series PEU pineapple lego help needed
Madmax908
DeLand, FL
I've been away from the forum for a while, and was looking to get back "into it".
This is what I want to build. (Thanks Solscud007) :drool:
This is what I have... (image from illuminationsupply.com)
It would be easy to get an E2D and swap everything over to this body (I think), but I don't have $150-200.
Can someone help me build a "pineapple clone" like Solscud007's above? (from CPV vendors?)
I'd like it to have "only" a 60cp led to keep the runtime long, and not ruin my night vision. (would red or green leds be better?)
I would also like to use a clicky that enables me to stand it on end.
I already have a crenellated bezel that a P60 fits into, and a Z48 cap if it helps.
Thanks
tx101
London UK
Your Z48 will not fit the Peu Pineapple, the Z48 is a C/P/Z series tailcap
The Pineapple is E series compatible therefore you need something like a Surefire Z68 tail clicky
or any other E series compatible tail like the Aleph tailcaps
See here
http://theledguy.chainreactionweb.com/product_info.php?products_id=1043
For a P60 head to fit the Pineapple you will also need a "C head E body adapter"
I believe Oveready may stock these.
As for your dropin, talk to member Nailbender. He can build you a dropin according to your specs
Tana
Bosnia & Herzegovina
Check the Lumens Factory for E2C adapter so you can use Z44 bezel... I believe they are the cheapest ones you can find (that seems like TNC E2C, LF is the copy of it I believe)... only OD color, though...
