AA is fairly permanent, but you can remove the emitter if you really want to. It's not easy, though. I blew an emitter and to replace it I had to bake the head for a bit to loosen the emitter, then remove it from the head with pliers. While removing it, the dome and black plastic casing seperated from the die, so be VERY careful if you're trying to salvage a working emitter. After removing the die, I still had to clean up the AA left behind so I could have a clean surface to mount the new emitter to. To get all the gunk out, I had to soak the head in alcohol (acetone supposedly works better) overnight and scrape a lot with a chisel.
