staffyman
I have a generic no-name cree powered torch that I got from an online auction site.
It's been working fine and I've been really pleased with it up until now.
It has stopped working and I think I killed the LED.
I noticed the beam wasn't looking right so looked into the head (not switched on obviously:duh2 and saw that the little dome covering the emitter had come off.
Upon closer inspection of the emitter there appeared to be an adhesive silicon(?) left behind on it that was causing the distorted beam. My thoughts were to clean this off and then the beam would be 'clean' again. I must have damaged one of the fine wires as it now longer works.
Using a multimeter, I have voltage across the + and - terminals on the emitter.
Is it just a case of de-soldering the emitter and then soldering another in place?
I have an Ultrafire C8 that I'm not happy with (it always changes mode everytime it comes on and I want single mode) that has an XML emitter.
Will this be OK as the original is a KM (so it says on it).
Voltages in both torches are the same as I run the C8 on an 18650 and the no-namer on 14500.
If you reckon it will be OK then I will swap out the emitter and then get a different one and a new driver for the C8. The C8 is intended for use on an air rifle with a remote switch hence the need for single mode. I'll open a new post about that.
Thanks in advance.
Thanks in advance.
