Quite honestly, I don't know how I feel about it, I have 2 Peak Logans, an 10180 Eiger and 10440 body (with a head on the way). When it works, it's brilliant- but I do seem to spend a lot of time faffing with it to make it work. Maybe I'll be happier when I get the momentary switch for one of my Logans. That all said, I haven't actually used my lights in serious anger yet (ie camping, power-cut, being chased by government forces through sewers etc) and they would probably be absolutly fine for those kind of duties, but when something's carried on my keychain/in pocket, the flaws are more apparent.
If Peak produced some sort of Gen.3 QTC pill then I think I would go on a buying spree. As it is, I've had mainly positive results (to a degree) with all sorts of tactics including packing the pill with aluminium/copper foil; magnets, spacers, lube, bigger bits of QTC, smaller bits of QTC..etcetc.. Current set-up in the Eiger I was having problems with is a 'doughnut' shaped spacer of paper to stop the two peices of metal in the pill coming into contact (and therefore stop the jump from medium to high).
Bottom line is, if you understand the limitations (ie- its not a magnetic variable control) then you shouldn't be disappointed.
I also only just realised that the Eiger Ultra X existed!
How come there is so little written about this light!?
