Which neutral emitter would you suggest swapping in an M3X? I found when using the XM-L in an open area the wide beam pattern picks up all the impurities in the air (glare) which counter acts the efficiency of the throw, if I'm describing this correctly. Much like the OEM XM-L Fury and the XP-G2 swap Wayne did to my other Fury. The narrower beam patter of the XP-G2 was far better when used in an open area.
Thanks!
Thanks!
