Jetbeam
Results 1 to 5 of 5
Thread: Nitecore EA8 showing 6.4 volts with new batteries?
    Nov 2005
    Amman, Jordan
    Default Nitecore EA8 showing 6.4 volts with new batteries?
    So I just got a Nitecore EA8 and love it so far. I've got a stash of alkalines I'm trying to use up before I go all rechargeable, so the EA8 seemed like a great way to do it. I already went through one set of 8 pretty quickly. It started giving me the under 50% flashes pretty quickly and wouldn't go into turbo mode after about a half hour of use. I tossed the batteries after about an hour of use, although my ZTS was saying "40%" on them, but I've had alkalines run so hard in other lights that the resistance built up so high that even with 40% on them they couldn't power a light well.
    So anyway, I replaced all 8 with new alkalines and the light reported to me that it has 6.4 volts of energy. Shouldn't it be 12 volts with 8 new 1.5 volt alkalines in it?
    Default Re: Nitecore EA8 showing 6.4 volts with new batteries?
    Maybe a short somewhere?
    Apr 2010
    Sweden
    I don't know about this light but it might be wired with 4 cells in series and 2 parallell and then your voltage seems just right with fresh alkalines.
    Nov 2005
    Amman, Jordan
    Quote Originally Posted by GunnarGG View Post
    Awesome! I figured there might be a good technical reason for it, but I don't know much about electricity and electronics. The light seems to be working just fine, so I knew that there had to be some explanation. Thanks, that's probably it!
    Flashaholic* Timothybil's Avatar
    Nov 2007
    The great state of Iowa
    If you read the manual it says that you can run on 4AA if put in the right slots. The batteries are wired in a 4S2P configuration - two sets of four batteries wired in series, the two sets then in parallel. And if the AAs happened to be 1.6v instead of 1.5v, that would account for the 6.4v reading.
    Remember, Two is One, and One is None!.
