gunga
For consideration for the Review forum.
4Sevens Preon Penlight Quickshot Review
Okay, due to family constraints, for the time being, my reviews will have to be quick impressions and observations.
First up, is the 4Sevens Preon Penlight. This is a handsome 2x AAA light that really does look and feel like a fine quality pen. A review sample was provided by 4Sevens, the regular retail price is $60.
Here are the specs, ported from 4Sevens.
Impressions & Observations
My overall impressions are very positive. This is a very nicely made light. The feel is nice and solid, with square threads, and adequate lubrication. The light was ready to go out of the box. Changing the batteries, of course, changes the weight and feel of the light. Those wanting a solid heft, should choose Nimh rechargeables, whilst those looking for the lightest possible option should use lithium primary cells.
The anodizing (in my case, the mocha colour) was flawless, with a rich lustre. The light has chrome (stainless) accents and clip, as well as a durable stainless steel bezel. There is a block/grid pattern on the body that adds visual interest, and perhaps a minor amount of grip.
The tail switch is a reverse clicky, with a very solid and firm feel. The switch requires roughly twice as much force to activate than the older Preon switches, so accidental activation is unlikely.
The clip seems solid and has a notch that fits a raised tab on the body. This is a clever idea and prevents the clip from rotating and scratching up the body.
The emitter is well centred in nice little reflector. There is a light texture on the reflector, yielding a broad spot with a fairly smooth bright spill. This is a very useful beam pattern for short to medium range use.
Tint is a pleasant cool white, with no hint of green or purple. My preference is for more neutral tints, but I will get to that later.
The UI is an interesting twist. The light has three brightness levels (5, 50, 180 lumens) and a unique memory mode with a hybrid reset. The memory locks based on "off" time. If the light is off for more than 1 second or so, the light will retain the last used level. However, once the level is locked, one can reset the light to low and scroll through the levels using a quick half press of the tail switch.
This is an interesting twist on the usual mode memory configuration and allows quick access to low, as well as a mode memory.
And finally, the redesigned packaging is quite sleek, showing the product as well as the included batteries.
Thoughts and Conclusions
As one can see, I do like this light. I find the hybrid memory to be innovative, allowing one to keep using a set level consistently, whilst providing a quick reset to low. I do wish the "off" interval could be reduced somewhat because I found the reset was a bit inconsistent at times. Also, I believe slightly lower medium and high levels would be more practical and offer improved battery life.
I think this light could be ideal for medical applications and such, and thus believe that a more neutral, high CRI (colour rendition index) emitter should be offered as an option. The light seems well glued, so modifications may be difficult. Hence, a factory neutral option would be nice.
The clip and overall size are very much like larger pens. The light is well suited for shirt pocket use, but the clip may not fair as well in pant pockets.
The pattern on the light, while unique, seems to take away from its elegant appearance. I feel a smooth, yet grippy finish would better suit this light (similar to the original, first generation Preon).
Finally, I don't find the price point to be ideal. At $60, this is an expensive light for the common market. I feel perhaps adding a titanium option (even at a higher price) would be ideal for premium or executive gift giving. Otherwise, a lower price point would make the light a lot more attractive for gifting. Most non-flashaholic people would just find that $60 is too much for a pen light.
I like the light, but find the price point may not be well suited for the target market(s).
Dimensions | Length: 5.3 inches/Body diameter: 0.5 inches/Head diameter: 0.5 inches/Weight (without batteries): 0.79 oz |
LED Emitter | CREE XP-G2 |
Voltage range | 0.9V-3V |
Spot Beam | Angle: 25 Degree |
Flood Beam | Angle: 74 Degree |
Brightness Levels | Low: 5 lumens, 30 hrs/ Medium: 50 lumens, 8 hrs/ High: 180 lumens, 0.4 hrs |
Special Modes | |
Reflector | Textured |
Body Material | Type-III hard-anodized aircraft-grade aluminum |
Bezel Material | Type-III hard-anodized aircraft-grade aluminum |
Lens Material | Hardened tempered glass lens with antireflective coating on both sides |
