Malkoff troubles
Bauer
I recently sent my m60 in for repairs because the light would turn a very dim blue tint running on 2x 16340, 2x18650's or 3x123 primaries. This is what I got back
Why is there so much crap trapped inside? How can i remove the optic to clean this mess out?
Norm
Retired Administrator
Australia
Have you addressed this problem with Gene or Cathy Malkoff?
If not it definitely should be your first call.
Norm
Bauer
Norm
No, I wanted to see if I could clean it out myself. I really don't want to have to send it off again.
Bauer
BTW I sent it in to Elzetta to get repaired so I don't think Gene is involved.
Cerealand
Have you put it in a host and tried it? Is the beam affected in any way?
Bauer
it functions fine, but I don't have another m60 to compare it to.
880arm
Wildlands of Western Kentucky
Yep, sounds like your first call needs to be to the guys at Elzetta. However, if you are set on trying to clean it out yourself, it still wouldn't hurt to contact Gene. I'm sure he could tell you the best way to take it apart.
fresh eddie fresh
I just got a used M60LL with an emitter that was off-center. When you shine it on the wall from a foot away you can tell, but in real world usage it is no problem at all. As long as the crud does not project in the beam you might be good, but I know sometimes it is tough to spend good money on something and not have it be perfect.
