Tobias Bossert
I need a rather compact reflector for flood application with XM-L2.
Formerly I used Carclo wide angle reflector 10170 with smooth alumine plating. It's diameter is about 20mm and FWHM is 80 deg. The spatial distribution is optimized to result in a flat illumination of a plane floor when mount in the ceiling - meaning the luminous intensity increases with off-axis angle. At the edge it is maximum and in the center it is minimum.
Carclo has a new reflector series with FWHM of 80 deg. Small diameter (16,6mm) and quite flat intensity response over the full beam. Part number at Carclo is 12531 (self locating). There are also models with holder clips and those with glue foil.
I googled, found al lot of hits, but found no reseller offering this new reflector.
Does anyone know a source for this new reflector.
I'm interested in a 'hand full' only, say 20 to 40 pieces.
Thanks
Thanks
