Chicago X
- Joined
- May 6, 2010
- Messages
- 439
Hi folks,
This Mag build is for a member here, who may identify himself if so inclined - I'm not going to blow his cover.
Using a Type-III coated 4D Mag as the host, this build will use the excellent PilotPTK fully-programmable triple XM-L2 module. This one has three 90 CRI 3000K XM-L2s, fed 3.44 amps each. AFAIK, this is the first use of the 90 CRI XM-L2s with this module.
Here's the host:
The bare module:
The optics used are the CUTE-3, a triple TIR lens. You can see three versions below, the narrow, medium, and (custom bead-blasted) frosted wide:
Here's what the module looks like with an optic in-place:
Since the module is ~34mm across, a fitment ring is needed to hold it in the larger Mag head. Here's a pic of the ring being machined out of T6061 aluminum:
Here's the trim ring, fresh off the lathe:
a
I think it looks better after a trip through the bead-blast cabinet:
Stay tuned for more...
Here's the host:
The bare module:
