Just because I was bored and had these parts, I put together a pill using a DownBoy700 and a SX1K 3W emitter. I used the Esink/Ecan setup for this and it is designed to fit into an E2e head. All I did was put my E2e head into a vice and drill it out with a 13/32 drill bit from the back side. The pill drops right in and and the light goes together as normal.
The beam has some throw, although not as much as a modded KL4 or KL1. What it does have is a lot of very nice side spill that is complemented with a hotspot that will give you a moderate amount of throw. What was surprising was running it in direct drive on an E1e body. Very nice this way. It's a very good light for total darkness, as it is not blinding, but will still light up a dark room.
I don't have anyuse for it and thought I'd post it to see if anyone would be interested in it, before I stuck the pill in my junk drawer.
I have $45 in it and will sell "the pill" only for that amount including priority shipping in the CONUS. If you're interested, post then PM.
