AardvarkSagus
Olight i3S
Olight's latest keychain torch, updated and improved. Are we looking at beneficial additions or unnecessary complexity?
Meat and Potatoes
Olight has a long and rich tradition in their EOS line of torches. Their keychain flashlights especially have long been heralded as cream of the crop. This latest iteration follows that time honored heritage with some incremental changes alongside more ostentatious alterations.
The i3S follows closely in the footsteps of its predecessor, the i3. Powered by a single AAA cell, this torch is a tiny powerhouse. Through the use of Cree's more powerful XP-G2 LED, the maximum output of the i3S has been boosted to 80 lumens. This is still quite conservative compared to what this LED is capable of, but it is very well matched to the capabilities of an alkaline AAA cell. Still sporting a miniscule textured reflector, the i3S manages a beautifully smooth beam that is appropriately floody for the kind of short range work generally seen by a keychain light. The LED is apparently driven by constant current regulation, since I can't spot even a hint of PWM. This is still something of a novelty with single AAA lights because of the diminutive size and reduced output capabilities. The "S" moniker indicates the presence of a warning strobe mode, accessed by quickly cycling through the 3 primary modes twice within a few seconds (more about those in a bit). This bears a strong resemblance to the old Preon lights. Thankfully this is tucked far enough out of the way to not be a nuisance at all. It's definitely not tactical in capabilities, but would serve as an adequate hazard signal in a pinch.
Build quality doesn't appear to have changed one bit between my last EOS reviews and now. Thankfully this is a good thing. Olight is now a mature flashlight manufacturer and they really seem to have worked almost all the kinks out of their production lines. Fit and finish of most of their lights, and the i3S is no exception, are exquisite. They have even heard and addressed some of the complaints I (and others) had about the last generation of i3. One of my biggest complaints was the structure of the keyring attachment. Previously it did not have the freedom and range of motion that I really thought it needed. The i3S seems to be completely free from this malady. The split rings have been upgraded to quality lobster claw attachments allowing quicker disconnects, and the actual attachment lug machining has been altered to now allow the chain to swing completely to vertical, eliminating much of the potential for tangled keys in your pocket. The previous bolted-on pocket clip is missing from this model, replaced instead with a simple tension fit clip, but it is still very sturdy and I haven't had any trouble with it yet.
Also gone appears to be the problems with mode skipping. I know this issue has the potential to exist within any twisty based light, but in the i3S I have been carrying for a while now, it hasn't shown its ugly head even once. Apparently the threads are tight enough to prevent too much play. This doesn't seem to have any negative effect on how smoothly they travel either. My sample has been smooth as butter one hand capable from day one.
Constructive Criticism
The i3S might not be a mode skipper, but Olight's choice of UI might make you wish it was a little bit. Instead of more traditional mode orders, this torch uses a Medium-High-Low(moon) order that takes a little getting used to. This change is not without merit, since 90% of the time Medium mode will likely be the mode of choice, but people really wishing to preserve their night vision have to transit from Med, through High before they get to the extended runtime level of choice. This seems like a bit of a questionable order to me. This is the type of light where I would personally prefer to see a mode memory or basic L-M-H order in place. It just makes more sense to me to have small pocket lights start at the lowest level and manually increase as necessary to preserve both night vision and battery life.
Conclusions
I have really grown accustomed to carrying a keychain light of some sort as a backup over the last few years. It's a natural place to keep a quality tool like this because it's almost always going to be near you or even on your person. Olight's i3S has really started to blur the line between simply being a backup light, and actually being a fairly capable primary torch. I'm still not ready to surrender myself to an AAA cell as my one and only light, but I know many people that wouldn't have that quandary once they experience what this torch has to offer.
Provided for review by the kind folks at GoingGear.
Conclusions
