Robocop
Moderator, *Mammoth Killer*
I have read here of people wiring two or more LEDs in series and also parallel.What is the difference between the two and what are the advantages of each method.I do not know the difference but I did manage to wire two LEDs together to use one power source.I put the neg. lead of one to the pos lead of the other.Pushed these out of the way and then used the two remaining leads to attatch to the battery.Both LEDs worked but it did not appear much brighter than one LED.Is this in series?By using the method I used are Both LEDs receiving less power than if I used only one?
