Some one gave me a push lawn mower the other day and i was using a ratchet to take a part off. While using the ratchet, it used to be smooth and quiet, noticed it had become rather "dry" and was clicking real loud when you'd "ratchet" it, meaning it was getting low on grease. I went to put some regular ol cup grease in it, it was actually the stuff i use to grease the front end of my truck, and my neighbor told me it's best to NOT put grease in one, but if you do put very little only on the forward/reverse switch and none on the gear. . the reason for this, is if you get it in a bind, like your taking off a rusted/frozen bolt, that when you put pressure on it, the grease can be so slick, that the gear inside will "slip" off and make the teeth get sheared down, or break off completely. and that it's best to leave it dry so it can get "better traction". common sense would dictate that if it was THAT bad rusted, then i'd use a breaker bar.
Has anyone ever heard of this before? or is he just repeating an old wives tale?
