ledlurker
Thanks to MR. BULK for the U3U SE\'s
Charlie, I bought 3 SE's from you many months ago. I Finally got around to heat sinking (hotlips) two of them and mounting a BB 700 in one for a 4C Mag. I mad two mistakes in my first mod ever. 1st, I clamped one of the emiters down to hard on the heatsink and deformed the emitter and had some silicon type goo get squeezed out of the die. My solution will be to mad scientist this one in a 6C direct drive and see how long it will last. 2nd mistake was to buy the wrong epoxy from Wayne Y. I ended up ordering the ceramic thermal compund by mistake, so I ended up useing this material to heatsink the BB700 and greasing the heatsink before installation into the mag 4C. I decided to use some Elmers gel superglue for the emitter bonding to heat sink which has worked very very well. My only suprise has been how much heat this assembly generates. I estimate the barrel and head has stabilized around 105F after about 15 minutes which proves to me that the emitter and heat sink have bonded well.
Now I just need to find some good high domes that wont break me and it will be time to upgrade.
Oh, I also used NaOH in removing the anodizing
I will post my runtime when the test is over. But I did get about 2 hours of use from pratically dead batteries last night when I went for a walk. The Led started to flicker when the batteries could no longer supply the current that the BB demands. I thought a had a cold solder joint but then after about 5 minutes the system dropped out of regulation.
