Vinz
Hi, folks!
I have to sell my last MD26E-UV drop-in to get the funds for an other high-lux project. It is the same drop-in as shown -here-, but equipped with a hand selected emitter. The amount of visible light and the Vf on this one are slightly lower than average.
The drop-in is designed to perfectly fit Solarforce hosts, like the L2, L2P, L2N, L2m, L2X, L2T and P1D using unprotected or short protected 18650 batteries.
Some details:
The Price is $120, inclusive international shipping. Express shipping (2-3 days) for whole Europe would be plus $4.
Some details:
- LedEngin LZ1-10U600 with 365nm.
- Soldered onto a Bergquist MCPCB using best Mundorf Silber/Gold solder (contains silver and also a small amount of gold).
- Constant brightness (constant current, no PWM!) and high efficiency thanks to a custom circuit with boost-buck converter from Texas Instruments.
- Up to 800mW on high mode (1.2A)
- Three well spaced modes
- Switch down to low mode at 3V and cut-off at 2.8V (2mA drain after cut-off)
- Best silver plated oxygen free copper wires.
- MCPCB is glued using Arctic Silver and the whole electronic is potted with a own made thermal adhesive, based on 75-80% of purest SiC.
- 11mm massive aluminium between the circuit board and the MCPCB. For example: The grounds on regular P60 brass pills are just 0,7-1mm thin.
