KeeblerElf
- Joined
- Dec 4, 2012
- Messages
- 218
Hello, CPFers! I'm trying to put together my first Lego, and I could use your help (please note that I've bolded some things in the hopes of increasing readability; I hope it's not perceived as obnoxious).
Here's the Lego build:
Questions:
For those of you who are curious, here are the desired properties of the light, based on my motivation to come up with a Lego for an ultra-reliable backup light - I may EDC it for a while, or eventually throw it in a glove compartment and forget about it for a few years. But I want it to be a light that I know will work (I do realize nothing is fail-safe, but I'd like this to be as reliable as reasonably possible).
Any and all feedback, links to other threads, beamshots, measurements, etc. are welcome. Thanks for any help!
- Malkoff MD2 head
- Malkoff MD1 body (modded by another CPFer; see the CPF Marketplace)
- Surefire Z41 tailcap with Oveready ZeroRez Shorty Z41 upgrade and 15mm spacer (if I understand correctly, this should turn the tailcap into a watertight, tailstand-capable twisty, capable of using up to 50mm cells if the spacer is removed)
- Possibly a Delrin tail shroud, if a pocket clip is desired
- (M60F or M31L or M31LL) with high/low ring
- M60F advantages: I perceive it as being tougher, due to the acrylic encapsulating the LED; can be used with a 16340 (or 18500 if the spacer is removed)
- M31L and M31LL advantages: regulated at 3V; can be used with a AA if the spacer is removed; better runtimes expected compared to M60F
Questions:
- Are there any physical incompatibilities you can see with this build? In other words, have I chosen pieces that will actually Lego together correctly? I believe I have, but as I said before, this is my first Lego build.
- How's the output of the M60F on a single CR123 primary? I realize it will be in direct drive at this voltage, but does anyone have ballpark lumen figures for the M60F at 3V on both high and low, or approximate runtimes on a single primary?
- Does anyone know how the M31L or M31LL with the high/low ring will run? I'm particularly interested in how useful the light is on low, and what runtimes I might expect on a single primary.
- For a primarily floody beam, should I consider putting a frosted lens if I end up using the M31L or M31LL?
- Do you see any obvious improvements I can make? My motivation and desired properties are below.
- Twisty switch
- Runs off a single primary
- At least two outputs
- Long run time on low
- Reasonably bright output on high
- Potted electronics
- Can tailstand
- Primarily floody beam
- Submersible and durable host (reasonable submersion - does not need to be a dive light)
