Workgeek50
- Joined
- Jul 2, 2013
- Messages
- 1
Can someone give me some info on this light? It was given to me by a friend
Hello WG50, :welcome:Can someone give me some info on this light? It was given to me by a friend
As this is a discussion subforum, please use the PM system to conduct transactions. Thanks,I'll buy it so you won't need to
There are two G2 LED's to concern yourself with, the older G2 LED, that uses a P60 swappable lamp assembly and has either a polymer head (older) or aluminum head (newer).I believe the older G2 LED used the P60L lamp assembly. It was rated at 80 lumens. The newer G2 LED used the KX4 head, which was rated at 120 lumens. You could tell the difference between the two as the newer one has KX4 written on the head, and the head itself is enclosed, with no swappable lamp assembly, and the older one had the swappable p60L lamp assembly. The older P60L was known for cooking itself to death over time, hence the upgrade in design to the KX4 head. It would not surprise me if the older version was available with both nitrolon and aluminium bezels.
