jarrett3612
- Joined
- Jun 24, 2013
- Messages
- 5
I have a simple mod to fix this problem. You simple take a washer that fits under the roller pin that the cam touches to move the bulb up and down. Then tighten it down so that it can't move at about the middle then reassemble and test it. I forgot this is if you have a cam/camless reflector you must make it cam less to work. I hope this helps people with this issue.
