I haven't used my SC52 in a while. I went to use it with a fully charged 14500 and it does not turn on to 500lm for the first minute like it used to. Anyone else have this issue? Any suggestions are much appreciated. Thanks
I've had no troubles with my SC52w in this regard but a few times I've had some minor issues like this with my SC51w. Try removing the battery for a few minutes. Then put the battery back in and wait a few seconds for the circuitry to "boot up". Make sure the tail cap is tightened properly. See if this helps. (Of course, make sure you've got the light programmed to operate the way you want it to like Hondo says. :ironic
