I'm building a little copper pocket rocket and I still have a few things to decide on.
The led:
A cree XPG2 or XML2 on a copper mcpcb.
The battery:
A small cyclindrical rc battery similiar in size to a AA, but rated for 25c draw or an IMR16340.
I plan on heavily over driving the leds, 3amps and 5amps respectivly.
I'm thinking direct drive for high and then a single amc7135 for low.
I'm leaning more towards the IMR16340 because I feel it would be smaller and more impressive when turned on
I'm going to use the same optic nomatter the led, a carclo 20mm narrow spot.
Do you think its worth using an xpg2 for the tighter beam? An XPG2 gives an 11 degree beam while an XML2 gives a 17 degree beam.
The led:
The battery:
