slebans
http://ledsmagazine.com/products/38706
SNIP
Cambridge Nanotherm's core IP is a unique process for converting aluminium into alumina. The process allows the surface of any aluminium object to be converted into a dielectric layer. In the case of the chip-on-heatsink approach, an extruded heat sink or heat pipe can be coated and then metallised with the end user's circuit design. Nanotherm's technology enabled Optocap to utilise its advanced manufacturing processes, allowing direct assembly of die and surface mount components onto the heat sink, creating a fully integrated module.
SNIP
